Removing 38-12 Dial Assembly
The 38-12 I have was in the home of a HEAVY smoker and the tuning capacitor needs to come off and be cleaned. How do I remove the dial pointer so I can take of the dial face? It looks like the pointer is put on with a pin forced into the center of the tuning capacitor shaft but removing it could bend the pointer. Any suggestions?
Richard
See here:
http://www.philcoradio.com/phorum/showth...5#pid89205
There are currently 5954 online users. [Complete List]
» 2 Member(s) | 5952 Guest(s)
