Airline 04BR-570A
Hello Does anyone have a the 6 volt dc power cord or an idea to replace it? I got the ac cord but it didn't come with the dc cord. It is very hard to hook it to 6 volt because it takes 3 terminals. Thanks for any help.
mike100860@yahoo.com Icon_biggrin
There's a diagram of the 6 volt connection at:
http://www.nostalgiaair.org/PagesByModel...010986.pdf
Its 2 wires but there is also an additional jumper on the 'minus' pin 6 over to pin 4. Plus is pin 1. Note thats the "face" side shown on the diagram but the numbering corresponds to normal tube pin numbering as seen from the pin base.
Eico 232 VTVM Schematic
There are currently 6480 online users. [Complete List]
» 2 Member(s) | 6478 Guest(s)
