Threads: 60
City: Kokomo, Indiana
For a very good condition Philco 20 standard Cathedral? I have one spotted and am watching it but asking price seems steep, she's asking $165.00. Most I've ever paid for a Cathedral/tombstone is $130 and it was a much cooler looking shouldered version GE in excellent condition. Thanks for your opinions.
(This post was last modified: 06-07-2015, 09:21 AM by Groundhog74.)
Threads: 112
City: Medford OR (OR what?)
If the grill is perfect, has a great original finish, NO rust on the chassis, ALL original parts in place and globe tubes, that is a fair price.
(This post was last modified: 06-07-2015, 10:39 AM by Phlogiston.)
Threads: 566
It depends on the state. Generally 20 goes for more information than plain cathedrals do. Up to $200 in the state Russ described is fair though one could haggle. And even without globe tubes. In your local non-auction case could be a bit less.
Threads: 154
City: Westland, MI
Offer a lower price, say $120.00 and see what happens. You can always go up. Take care, Gary
Threads: 268
I'd bring an ohm meter to check the spkr field coil and output transformer. Those K spkrs are expensive!
Threads: 566
field is even more important, the transformer can be replaced, but the open field means taking the speaker apart and possible reconing.
Threads: 60
Got the 20 today. She dealt with me a little and I got it for $150. Cabinet is dull and I am gluing some loose veneer but overall very good. Looks like one previous repair on grill but very well done. All tubes good (alas no globes) and it works but is a little low on volume and scratchy. Not sure if grill cloth is original but it's a good repro if not. All internals look original except power cord. Trying to post pics bit my wife's IPad isn't cooperating.
Threads: 566
Decent price for a 20. Can vary, but not bad at all.
Threads: 60
Threads: 60
Threads: 60
Threads: 60
Threads: 60
Threads: 60
Sorry in advance, I know I did not post photos correctly, but between this IPad and the mosquito swarm dining on me out here in the garage I've about had it for today.
Threads: 566
Looks like someone attempted refinish.
Will have to get correct color.
Does the speaker work?
Gary
I in fact did, on a 38-14, I think, where I had a speaker with the dead coil.
Well...it kinda worked. Kinda, be...morzh — 10:38 PM |
Mike, what ever happened to that plan you had to try using a rare earth magnet to magnetize the pole? This looks like a...GarySP — 10:25 PM |
RCA T62 is playing.....
Beautiful set.morzh — 09:07 PM |
Well....here it is.
The green stuff. Unfortunately, probably penetrates deep.
I opened the top layer and saw that:
...morzh — 08:58 PM |
Philco 91 Restore Code ??
:clap: :clap: :clap: :clap:
Really nice workmanship!!! Top of the chassis looks great.
Sorry about the long winded e...MrFixr55 — 08:09 PM |
Philco 40-120C Restoration
Thank you for your reply. I will check voltages on the other tubes, look at resistor 23 and cap 25, etc. If all else fai...bluecap — 07:58 PM |
Nice looking set great save. DavidDavid — 07:48 PM |
Philco 89 indicator light.
Hello Jim, I have done several 89s. The trick is to move the drum in or out on it's shaft. You will need to loosen a set...dconant — 07:36 PM |
MrFixr
Yes, it is my plan to go with 45rpm spider if I go that far.
No, the pole was not left-handed as I unscrewed ...morzh — 07:14 PM |
Change the tube. Check the tube's bias network.
Are any other tubes experience the drop or just this?`
Is resistor 23 OK...morzh — 07:09 PM |
There are currently 6192 online users. [Complete List] » 1 Member(s) | 6191 Guest(s)
