Philco Battery Pack P 60D-11L
Threads: 55
City: Evanston, IL
Hi,
I'm not near my archive and can't be sure of the battery voltages on this Philco A-B pack. I believe it's 1.5 volts, since the tubes are 1-volt types for A but can't be sure of 90 volts for B. Battery-Bill are you "out there?"
Chuck
Just looked in my 1941 and 1946 parts catalogs...both list this battery but neither gives the specs, unfortunately.
Threads: 54
If it's from the 1940s then more then likely it's 90VDC for B+, I have not seen too many sets from then with 67.5 volts in portables as there was in the 1950s.
Best Regards
Threads: 11
City: Indianapolis, IN
1.5v A, 90v B. Equivalent to an Eveready 759 Farm Pack.
Bill
Threads: 55
City: Evanston, IL
Thanks Ron, I looked thru all my Philco Parts Calatogues too - same thing.
Finally, figured out that it is 1.5/90 from various battery set's schematics and voltages and tube data.
Thanks Bill. My client for the Model 41-90 also got a info sheet about your battery repro service with your email in my info packet.
You should get a small website with more pics and specs & details.
Chuck
Threads: 11
I'd love to, but the way I want to do it would take a lot of time, and with my orders now, I don't have that!
However, this is roughly what I'd like it to look like. I dummied it together as a test, borrowing heavily from your website's layout, Chuck!
http://level1.midwestinternet.com
Threads: 55
City: Evanston, IL
Wow Bill! Great start.
The page layout template is not mine, just found one I liked from a template site and did some hand-coding HTML on it.
C'mon....make those links work. ;)
Chuck
PS Mind if I use the ad graphic to enhance your link?
Ditto what Chuck said! Bill, you have the beginnings of a very nice website.
Threads: 11
Thanks much. Now it's just a matter of implementing it....
Threads: 117
Batterymaker, Great looking website fnt page indeed! Do you also service vintage winchargers? I know these are hard to come-by these days, dont see many anymore. If someone could re-produce blades & rotor system, the old style d.c. type automotive heater-fan motors produce dc voltage into batteries for recharging when spinning in free air.I knew a old-timer that built one before. The dc motors rotation doesnt see a +/- difference in rotation ( from its 2 connectors). Having a new style, vintage-type wind-charger for storage batterys could be fun to build?.. and experiment with? Could also be used as a "trickle" charger for auto, or lawnmower batteries? Just a idea.
Threads: 110
City: Omak
State, Province, Country: WA
Hello batterymaker ,
well far as that Batter for 40-90 how long does it take you to build something like that also do you use 9 volt and
also what about a battery for my 46-320 I think thats the model it's the philco with roll top
Sincerely Rich
Threads: 11
Texasrocker Wrote:Batterymaker, Great looking website fnt page indeed! Do you also service vintage winchargers? I know these are hard to come-by these days, dont see many anymore. If someone could re-produce blades & rotor system, the old style d.c. type automotive heater-fan motors produce dc voltage into batteries for recharging when spinning in free air.I knew a old-timer that built one before. The dc motors rotation doesnt see a +/- difference in rotation ( from its 2 connectors). Having a new style, vintage-type wind-charger for storage batterys could be fun to build?.. and experiment with? Could also be used as a "trickle" charger for auto, or lawnmower batteries? Just a idea.
No, I've only seen one in twenty years, and reproducing something like that is beyond my Jedi powers.
Threads: 11
radiorich Wrote:Hello batterymaker ,
Sincerely Rich It doesn't really take that long--what takes awhile is fitting in time to build them. I'm taking care of my family and my mother, and time needed for both of them is in high demand.
As for the 46-320, I can do that one. Its battery is the equivalent of an Eveready 753.
Threads: 110
City: Omak
Hello Batterymaker,
I know what you mean about family we have had a lot of family stuff to do around here far as that Philco 46-320,
goes thats sound great also Texasrocker far as a wind charger goes I sure wish build it I have room but I'm surrounded with trees don't know how well it would work.
Sincerely Rich
Threads: 2
Just as a reference on batteries made from WW-2 and prior, the Radio Troubleshooters Handbook by Ghirardi has a section in the back of the book with different brands and their numbers, voltages and sizes and even the type of connector (no pin out). Pretty helpful if needed.
Hi Mike, I believe I tried different ways to change the header for my post but no luck. Anyway thanks for changing it fo...462ron — 04:02 PM |
Since these radios operated in harsh environments (temp changes and vibration) you could touch a soldering iron to all t...GarySP — 03:18 PM |
Thank you Gary. Hi Morzh. These radios are 6 transistor radios. Sadly no tubes. Thanks though.R3Sons — 02:19 PM |
Ron
Instead of Quick reply, go to New Reply, then go to the title of the very first post, and change the title text the...morzh — 02:00 PM |
I am not a specialist in car radios.
I suspect they might use vibrators to convert 12V to acceptable tube voltages, so ...morzh — 01:58 PM |
Welcome to the Phorum, R3Sons! I have very limited experience with car radios other than installing custom radios back ...GarySP — 01:08 PM |
OK, I need to rename this thread to say..Eico 368 TV/FM Sweep Generator instead of the current title..Heathkit Sweep Gen...462ron — 12:49 PM |
Hello, I have a Philco (Ford) 6TPZ and a 5TPO radio. I replaced the electrolytic capacitors in both. I have the SAMS m...R3Sons — 12:29 PM |
Hello Peter,
Thank you for posting that !!
Eico 232 VTVM Schematic
There are currently 9662 online users. [Complete List] » 1 Member(s) | 9661 Guest(s)
