Philco 46-1201 Phono Cartridge
See post #3 below for information on a cartridge for a Philco 46-1209 radio-phono.
Meanwhile, enjoy some photos of Greg's 46-1209 with gold accents on the knobs, hand applied.
- admin
May I ask where one may locate a replacement needle and cartridge for a Philco 46-1201? I love this model and the technology involved. And it's one of my most wanted units.
Ian M. Gordon
NEARC
HARPS
This is the go-to place for cartridges and idler wheels for me: http://www.thevoiceofmusic.com/
I hand painted the gold on the knobs of my 46-1201. Really dresses them up. I do that on Hippo models too, which use the same knobs.
That model No. from VM is KCCC. It's a barrel type with both 78 and LP styli. It has a higher output voltage than other's you might use. I believe the output volts. are 1.3 volts. I just ordered one yesterday.
Since Jim added some useful information regarding the phono cartridge for this model, I decided not to delete the entire thread, even though the radio has been sold. I will leave it up to the moderators if they wish to leave this thread or delete the whole thing.
Per Greg's suggestion, I have converted this thread from a "for sale" ad into a restoration topic.
Thanks, Ron.
There are currently 4044 online users. [Complete List]
» 1 Member(s) | 4043 Guest(s)
