E.H.Scott Military Receiver RCH
Here is a receiver that I friend in Illinois gave me. He had no idea of what it was. I think its a E.H. Scott RCH receiver. Here are some pictures..
[Image: http://i292.photobucket.com/albums/mm38/...xor1cg.jpg]
[Image: http://i292.photobucket.com/albums/mm38/...c5nrtk.jpg]
[Image: http://i292.photobucket.com/albums/mm38/...0dhu0d.jpg]
No markings on it anywhere .. Its missing the name plates..
It seems to match this picture of a RCH..
[Image: http://i292.photobucket.com/albums/mm38/...sa8pug.jpg]
Can anyone positive ID this?
Thanks
Skip...
No expert on these Skip but the chassis picture on the RCH sure appears to match what you have perfectly as far as I can see.
Jerry
Better keep up on ur vitamins!!! Looks like a backbreaker!!!!
Don't know much about your rx. Have seen a few over the years but never took one home.
You may try the ARC-5 forum over at yahoo. They discuss some other military stuff other than ARC-5 stuff.
Ok thanks for the info.. Its built like a tank.. Covers ..
[Image: http://i292.photobucket.com/albums/mm38/...tbyox6.jpg]
I think it was used on Navy ships. Receives well. I did download the manual.. I am going to do a full alignment and then probably sell it.. No room for it as I have my 2 R-390's , the Collins R-388 and a Big old Hallicrafters SX-101 RX and the HT-32 Transmitter.. which take up a lot of room..
Thanks
Skip...
Tis easier to buy a bigger house.
    These were also used in a Mackay shipboard communications console after the war, under the designation SLR-F.
Very Interesting..
Thanks
Skip...
The speaker table error?
Philco 70 antenna lead
