Threads: 36
City: Brandon, SD
I just picked up a model 20 console for $40. The cabinet is kind of rough and has been painted but it is complete right down to the grille cloth which unfortunately has a tear in it. My question is how rare is the Model 20 console vs the cathedral? I was also wondering if the chassis and speaker out of it are a direct fit into the cathedral cabinet? If they aren't that rare I would like to find a cathedral cabinet to put the chassis in, unless they are super rare and it is deserving of a top shelf resto.
Threads: 566
There was 340,000 cathedrals and 70,000 of plain grill lowboy plus 16,500 of latticeworked lowboy, so you draw the conclusions. Yes the chassis and the speaker are the same.
Threads: 36
City: Brandon, SD
Does the plain grille work mean it's the one that looks like it's frowning at you?
Threads: 566
Yes. I have the other one, it is rarer.
In our neck of the woods they do not pop up much at all, either one.
Threads: 22
City: Waxahachie, TX
I picked a Philco 20 Lowboy a couple of weeks ago with a decent cabinet and a very good chassis. Paid $60 for it.
See here:
http://philcoradio.com/phorum/showthread.php?tid=12361
Crist
(This post was last modified: 06-22-2015, 08:59 AM by Crist Rigotti.)
Threads: 54
(06-21-2015, 10:32 PM)sdradioman Wrote: I just picked up a model 20 console for $40. The cabinet is kind of rough and has been painted but it is complete right down to the grille cloth which unfortunately has a tear in it. My question is how rare is the Model 20 console vs the cathedral? I was also wondering if the chassis and speaker out of it are a direct fit into the cathedral cabinet? If they aren't that rare I would like to find a cathedral cabinet to put the chassis in, unless they are super rare and it is deserving of a top shelf resto.
I would leave the console alone since it sounds like it;s the rarer version and just find a complete cathedral model 20 elsewhere as they turn up fairly regularly. There you have two choices, the plain brown wrapper early version, or the more elaborate late version with the figured maple arch on the front. You could also buy one with a damaged cabinet and buy a reproduction cabinet, or parts, from Steve, and decide which version you like.
(This post was last modified: 06-22-2015, 03:28 AM by Arran.)
Threads: 92
City: Clayton, NC
Steve makes some d**n fine repops!!!!
Threads: 566
Does he make 20s too?
Threads: 72
City: Linn Creek, MO
Not yet.
M R Radios C M Tubes
Threads: 566
Thought so. That's why I asked.
So Radioman can count only on finding existing cabinet. I have not seen many. That is, I saw none, so far.
Threads: 36
City: Brandon, SD
Sorry I haven't posted for a while, my graphics card went out of my computer. So I picked up this model 20 console. It is complete and the chassis is in fair shape with only a couple small spots of rust. The speaker is in great shape. I have a question though. Did they come from the factory with a back on them? The one I bought has a back on it and it appears that it possible could be original, or someone in the past built a excellent cover. It in no way looks like a cheap handmade piece. Can anyone varify if they did or didn't come with one?
Threads: 271
City: Wilsonville
State, Province, Country: OR
How about a picture? Thanks.
Model 20 consoles did not originally have backs on them.
Threads: 36
City: Brandon, SD
Ok, I will pitch it then. Thanks for the info Ron!
Gary
I in fact did, on a 38-14, I think, where I had a speaker with the dead coil.
Well...it kinda worked. Kinda, be...morzh — 10:38 PM |
Mike, what ever happened to that plan you had to try using a rare earth magnet to magnetize the pole? This looks like a...GarySP — 10:25 PM |
RCA T62 is playing.....
Beautiful set.morzh — 09:07 PM |
Well....here it is.
The green stuff. Unfortunately, probably penetrates deep.
I opened the top layer and saw that:
...morzh — 08:58 PM |
Philco 91 Restore Code ??
:clap: :clap: :clap: :clap:
Really nice workmanship!!! Top of the chassis looks great.
Sorry about the long winded e...MrFixr55 — 08:09 PM |
Philco 40-120C Restoration
Thank you for your reply. I will check voltages on the other tubes, look at resistor 23 and cap 25, etc. If all else fai...bluecap — 07:58 PM |
Nice looking set great save. DavidDavid — 07:48 PM |
Philco 89 indicator light.
Hello Jim, I have done several 89s. The trick is to move the drum in or out on it's shaft. You will need to loosen a set...dconant — 07:36 PM |
MrFixr
Yes, it is my plan to go with 45rpm spider if I go that far.
No, the pole was not left-handed as I unscrewed ...morzh — 07:14 PM |
Change the tube. Check the tube's bias network.
Are any other tubes experience the drop or just this?`
Is resistor 23 OK...morzh — 07:09 PM |
There are currently 6377 online users. [Complete List] » 1 Member(s) | 6376 Guest(s)
