Unknown Philco Tombstone Cabinet
Guys,
Need some help to ID this tombstone cabinet. What's interesting is the metal escutcheon around the tuning and tone controls.
Thanks.
[Image: http://i1060.photobucket.com/albums/t458...0d4d8v.jpg]
Crist
I'm not sure what Philco model that is, but that metal escutcheon is not original.  It came off one of those cheap Chinese reproduction radios, and this looks like the radio it came from:
http://www.ebay.com/itm/Divine-Model-Ant...3cfd532f09
Somebody butchered that philco  Icon_wtf
Looks like a 620 that someone routered out the two new holes on each side of the dial. Freds right, butchered.
Yep, looks like a butchered 620 cabinet!
Crist
Mike and Crist are both correct. It appears to have once been a 620B cabinet that is now butchered. Icon_thumbdown
 If that cabinet were cheap enough I would buy it if I ran across it, for cabinet parts. My Philco 620's cabinet was the victim of a moron with a disk and a drum sander, with which they mutilated the poplar millwork on either side of the front control panel.
(07-06-2015, 03:54 AM)Arran Wrote:   If that cabinet were cheap enough I would buy it if I ran across it, for cabinet parts. My Philco 620's cabinet was the victim of a moron with a disk and a drum sander, with which they mutilated the poplar millwork on either side of the front control panel.
Yes, a good point!
Crist
To bad someone defaced that radio cabinet. What does it say on the medal face plate?
With the six whiskers it makes it a 116 or maybe 650.  The 620 has only four whiskers.
That escutcheon doesn't belong there.  Why do people sand finishes??  That just drives me up a wall.
Pete AI2V
Well, I won it and another 630 tombstone cabinet and chassis at the auction. Paid $25 for the lot.
Crist
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
