Philco 90 original finish preservation
So I purchased my beautiful model 90 with its original finish. The previous owner said that all he did was wipe the cabinet with lemon oil. It has the normal aged lacquer cracking to it but it's in great shape. I'm wondering what is the best way to preserve and protect the original finish? Is there a curtain product that will keep the finish from breaking down any further?
I have sometimes used a penetrating oil finish on aged lacquer: thinned varnish, boiled linseed oil, tung oil, Minwax "Antique Oil," there are many. Occasionally I've heated the surface with an infrared lamp to aid penetration. Any oil remaining on the surface is wiped off before it sets.
(07-09-2015, 08:03 PM)Alan Douglas Wrote:  I have sometimes used a penetrating oil finish on aged lacquer: thinned varnish, boiled linseed oil, tung oil, Minwax "Antique Oil," there are many.  Occasionally I've heated the surface with an infrared lamp to aid penetration.  Any oil remaining on the surface is wiped off before it sets.
Very very intresting Icon_wtf
Maybe try Kramer's Antique Improver:
http://www.kramerize.com
^^I haven't tried that product yet but I was just reading over at the other joint about it. Sounds like a good product.
Let's try to sort it out. So we are working with the same info here's the schematic I have: ...and here's the pin o...klondike98 — 09:03 PM
Philco 630csx power cord
I posted this on FB but knowing that not all of us use social media, it seemed sensible to ask my question here.  I r...Tynwald — 08:07 PM
Philco 40-155
At last, got this working well. Impressed has really nice reception and tone. Had a bad connection on one of the capaci...rogerh — 07:44 PM
Philco 91 Restore Code ??
Or you could just square the current :lol: As for the values, they are dependent on the 1 or 2-speaker system. The...morzh — 05:46 PM
If you know the fc resistance you can use 120 ma nominal current through the resistor to get the voltage drop then calcu...RodB — 05:21 PM
Thanks Mike. I at least know why it is there if I don't fully understand it. I see where you talk about a cap and resist...dconant — 04:49 PM
Well, this cap you showed cannot possibly, due to the way it is constructed, be 1000pF (0.001). It can be in tens of pF....morzh — 03:13 PM
I have two schematics for this radio one shows the 47 block (126-226) and the other (121-221) does not. My radio does no...dconant — 02:32 PM
No, that cannot be the 47. The 47 is a regular backelite block cap. Look at the chassis picture, it is shown there. Rig...morzh — 01:45 PM
There are currently 2069 online users. [Complete List]
» 1 Member(s) | 2068 Guest(s)
