Philco Battery Pack P 60D-11L
Hello Jim,
thanks for the tip I'll try to find that book to add to my collection
Sincerely Rich
Have you considered having the insides made as a plastic injection? You could even eliminate the separate cell / battery holders, as the terminals and so forth could be cast into it.
Web site: http://www.masekconsulting.net
Radio Photos: http://www.photobucket.com - album id FStephenMasek
Chuck Schwark Wrote:Hi,
I'm not near my archive and can't be sure of the battery voltages on this Philco A-B pack. I believe it's 1.5 volts, since the tubes are 1-volt types for A but can't be sure of 90 volts for B. Battery-Bill are you "out there?" Icon_smile
Chuck
Hi Chuck,
Here's a scan I made from a 1958 Eveready Batt. replacement guide.
You can go by radio model number or go at the last pages, find the Philco batt model, cross reference to Eveready and many other brands too.
The voltages are shown in the second column.
Hope this helps in the future.
-Direct link to save you time, but available through my schematics and data page:
http://www.oldradioz.com/data/eveready_b...guide.djvu
Syl
Hello Syl,
Thanks for the info.
Sincerely Rich
There are currently 8521 online users. [Complete List]
» 1 Member(s) | 8520 Guest(s)
