Aerovox Dry Electrolytic Capacitor
here a helpful site
just type in tube shows pin out and sub tubes
http://tdsl.duncanamps.com/tubesearch.php
sam
There are currently 5761 online users. [Complete List]
» 1 Member(s) | 5760 Guest(s)
