Threads: 104
City: Calgary, AB, CA
Threads: 55
City: Lexington, KY
(07-16-2015, 09:38 PM)Dan Walker Wrote: ........ I sure do like these Rogers radios.....
I can sure see why, those are beautiful.... great job!
Threads: 569
Ooh, yeah....
Threads: 147
City: Dallas, TX
Threads: 104
Thanks for the kind compliments.. It took a while but I wanted to get it right. It was good that I had one with the original finish on it so I could match the other one to it. Now you may see why I wanted original Rogers grill cloth
Dan
Living in Calgary Alberta
Threads: 147
City: Dallas, TX
Hey Dan ,Richmond Design's has a new diamond pattern grill cloth very close to your Rodgers, cant tell the size of diamonds but may be close and color is real close also
Threads: 97
City: Poughkeepsie, N.Y.
Nice radio indeed! The wood on that console is stunning!!!
Threads: 271
City: Wilsonville
State, Province, Country: OR
Threads: 69
City: Kansas city, MO.
Excellent job Dan. That cabinet can hold its own in any high end setting.
By the way how do the Rogers radios sound?
Threads: 104
These rogers radios sound very good. It has a 12 inch speaker. and it is about the heaviest speaker that I have ..
Some of the other radios that I have sound good but this has a very nice rich tone.. With 10 tubes it does sound nice.
I could not give you technical aspects of the radio as I am not a tech, but if it sounds good to my ears then I like it. Now I have to find or make a power supply for one of them. I need another clock and hopefully one will come along.
Thanks again for the comments. Dan
Threads: 69
Good to hear they sound nice as they look. The clock might be a challenge to find. I'm sure someone on here can help you with how to build a power supply. Good luck.
Threads: 147
City: Dallas, TX
Dan I have some old cloth that looks like or very close, I will get a picture of it and show you. It just may work!
Threads: 104
Thanks Fred... Since I live up here in Alberta, there is a good chance that I will run across a Rogers console that I can steal the cloth from..
I would buy the radio and use the cloth on the 10-12 and put something different in it , Just to have the right one on the 10-12
Threads: 147
City: Dallas, TX
Threads: 416
City: Boston
Super deluxe job, yow!
The speaker table error?
G 10-1/2" 65, 76, 87, 95
Push-Pull 45's
2766
0.7
550
3200
H 10-1/2" 77, 96
Push-Pull...morzh — 09:26 PM |
I have a Stromberg, one of the early ones, seems early 30s.
This is what I call a back breaker. None of the early Philc...morzh — 08:28 PM |
A backbreaker.....PaulPaul Philco322 — 08:12 PM |
>>What a behemoth!
A Juggernaut.morzh — 07:47 PM |
Philco 70 antenna lead
I am not sure I understood about the coils and the mush. I looked an more than one coil in 20, 70, 90, 60, Zeniths and ...morzh — 07:46 PM |
:e_biggrin: What a behemoth! I hope the final result is as much a quality sounding example! Keep us posted on your pro...GarySP — 07:32 PM |
I should add that the double conversion may only be used on the shortwave bands, but I haven't looked at the schematic t...Arran — 07:27 PM |
Yes, that wire will not pick up much interference as routed - the RF at that level won't be affected, and if you have st...radio1 — 07:26 PM |
I'm also a member of MARC. Did you attend the Vintage Electronics Expo in Waterford, MI last month? That's where I got...GarySP — 07:22 PM |
Dan
Double conversion is using two IF converters instead of one. This improves the image response.
morzh — 07:15 PM |
