Crosley 66TA loop antenna manufacture
My Crosley 66TA has no back panel of course, but I thought I might try to make one including a loop antenna. I've attached the only picture I can find on the net of the Crosley 66TA loop antenna. It seems to be a simple flat loop of about three turns with a lead at each end of the loop running around the edge of the fiberboard back. Does anyone have a live version of one of these to confirm? Can it be that simple? I'm a bit surprised by this since the sets are supposed to be great at pulling in signals.
Charlie in San Antonio
Looks like a simple but effective antenna.
I would suspect that you could use a loop from another set. Most AMBC sets use a 365mmfd tuning cap and the ant section. So the capacitance is all about the same. The other critical part is the inductance since most loop are used with a 365mmfd cap you should be in business. You will need to repeak the ant trimmer for best sensitivity at the high end of the band.
There are currently 5074 online users. [Complete List]
» 1 Member(s) | 5073 Guest(s)
