Rogers 10-12s finished
  I finally got these two cabinets finished. The one with the grill cloth in the center hole is the one with the original finish on it,  except for the narrow trim, which I had to redo. The other one was the one  that I had to totally redo. that is the one with the gold decals and the glass installed. I only have one complete chassis,clock and power supply. I do have the another chassis that needs work..   I sure do like these Rogers radios..
  Dan in Calgary
   Living in Calgary Alberta
(07-16-2015, 09:38 PM)Dan Walker Wrote:  ........ I sure do like these Rogers radios.....
I can sure see why, those are beautiful.... great job!
Ooh, yeah....
 Hey Dan that's the nicest radio I've seen in my life, I showed my wife I she fell on the floor Icon_clap Icon_clap Icon_clap Icon_clap Icon_clap Icon_clap Icon_clap
    Thanks for the kind compliments.. It took a while but I wanted to get it right. It was good that I had one with the original finish on it so I could match the other one to it. Now you may see why I wanted original Rogers grill cloth
 Dan
Hey Dan ,Richmond Design's has a new diamond pattern grill cloth very close to your Rodgers, cant tell the size of diamonds but may be close and color is real close also Icon_wave
Nice radio indeed! The wood on that console is stunning!!!
Outstanding!!!
Excellent job Dan. That cabinet can hold its own in any high end setting.
By the way how do the Rogers radios sound?
    These rogers radios sound very good. It has a 12 inch speaker. and it is about the heaviest speaker that I have ..
   Some of the other radios that I have sound good but this has a very nice rich tone.. With 10 tubes it does sound nice.
          I could not give you technical aspects of the radio as I am not a tech, but if it sounds good to my ears then I like it.    Now I have to find or make a power supply for one of them. I need another clock and hopefully one will come along.
     Thanks again for the comments.     Dan
Good to hear they sound nice as they look. The clock might be a challenge to find. I'm sure someone on here can help you with how to build a power supply. Good luck.
Dan I have some old cloth that looks like or very close, I will get a picture of it and show you. It just may work! Icon_eek
     Thanks Fred... Since I live up here in Alberta, there is a good chance that I will run across a Rogers console that I can steal the cloth from..
    I would buy the radio  and use the cloth on the 10-12 and put something different in  it , Just to have the right one on the 10-12
(07-17-2015, 12:13 AM)Dan Walker Wrote:      Thanks for the kind compliments.. It took a while but I wanted to get it right. It was good that I had one with the original finish on it so I could match the other one to it. Now you may see why I wanted original Rogers grill cloth
 Dan
Dan I have some used cloth that mite work for clock opening
Super deluxe job, yow!
The speaker table error?
Philco 70 antenna lead
