viberators 6 volt 4 pin
Would some one be able to help me to service these viberators as I have 6 and not working  all help will be apreaciated   .kind regards john Icon_rolleyes
Welcome to the Phorum!!! Icon_wave
There are several guys on here who restore these sets so hopefully someone will chime in soon.
With regards to car radio vibrators, there is a company in the states that manufactures new solid state replacements that work great. My dad was able to find the elusive one he needed for his Chrysler Highway hi fi record dash mounted record player. Here's a link to the company: http://www.radiosforoldcars.com/productsF.htm
Welcome to the Phorum, found this a few years back on the internet. Just use a 6 volt step down and pack every thing inside the old can hope this helps. David
many thanks for ansering my message as regards he vibrators most helpful anyone that has played with them I would like to here .Regards to all John
If you would like to buy the solid state ones contact me.  Bill
There are currently 9766 online users. [Complete List]
» 1 Member(s) | 9765 Guest(s)
