Using Gojo Creme on veneer
It also works on Bakelite cabinets. It is great for removing paint spots. Rub lightly with #0000 steel wool dipped in GoJo.
Eric
The Villages, FL
There are currently 7574 online users. [Complete List]
» 3 Member(s) | 7571 Guest(s)
