Philco 84 Restore
I am just finishing up a restore of a Philco 84 cathedral.  I had to rewind the primaries on the antenna and oscillator coils.  I replaced all the capacitors. I also replaced all the dogbone resistors. I have adjusted the regeneration control, and peaked the IF capacitors.  It is playing with pretty good volume with only an 8 ft. piece of antenna wire.
I need to still make the 2 meg ohm resistor change from the service tip in the IF transformer to see if it plays even better.
Question...I noticed that someone had removed the "gimmick" capacitor (#3) so I replaced it.  It seemed to make no difference.  What exactly is the capacitor doing?  Coupling a little extra signal from the antenna to the oscillator?
Why would it seem to not be needed?
Mark K8KZ
Hi Mark.  I have that same gimmick cap in my 41-280.  My guess is it works as a filter.  I don't know exactly how, but others on this site can offer more info than I can.  All I know is that I was told to keep it in the circuit or you can pick up a lot of "white" noise.  Take care, Gary
There are currently 6627 online users. [Complete List]
» 2 Member(s) | 6625 Guest(s)
