40-201 finish restoring question
ready for restore of finish - the case is in nice shape with normal minor scratches and the finish is dirt of course. Can you recommend any articles/threads discussing restoring the finish? I'm not looking for a museum piece, but want to keep the original finish without ruining it and touch up what makes sense.
Thanks!! DVW
Try this:  GoJo
Eric
The Villages, FL
Yes the gojo will.clean off the dirt, grime, cigarette smoke etc. After that some Howards Restore-a-finish will make scratches less noticable and freshen up the original finish without really changing it. It won't fix cracked or alligatoring lacquer.
Model 27-84 BUZZ?Humm?
Philco 630csx power cord
Let's try to sort it out. So we are working with the same info here's the schematic I have: ...and here's the pin o...klondike98 — 09:03 PM
