1939 Stromberg Carlson 430-H Restore on YouTube
(07-05-2015, 02:15 PM)sam Wrote:  buzz
great song love the way you illustrated it
dickel was very cooperative I see Icon_clap Icon_clap Icon_thumbup
sam
Dickel has the hots for the spirit in the sky........Buzz
Hello Phorum:
Part 3 of my 1939 Stromberg Carlson 430-H series now uploaded.
A link below is for anyone interested...thanks
https://www.youtube.com/watch?v=hCQscu93wDw
Hello Phorum:
Part 4  of my 1939 Stromberg Carlson 430-H series now uploaded.
https://www.youtube.com/watch?v=90mMj-etfiY
That was a close shave for ole' Dickel.
Your cap restuff looks pretty good, but they sell hot glue that is a more tan/brownish color that would look a little better.
Good work and thanks for the videos!
Hello Phorum:
Part 5  of my 1939 Stromberg Carlson 430-H series now uploaded.
https://www.youtube.com/watch?v=dasIPycCWlE
Interesting and entertaining video as always.... thanks!
Congratulations on the potato contest!
Hello Phorum:
Part 6  of my 1939 Stromberg Carlson 430-H series now uploaded.
https://www.youtube.com/watch?v=rnXTrM-pe7Q
(08-02-2015, 04:10 PM)Eliot Ness Wrote:  Interesting and entertaining video as always.... thanks!
thanks eliot
Buzz;
  A lot of 1936-38 RCA sets used a similar chassis isolation system to your Stromberg Carlson, fortunately most of the ones I have found are still usable. The closest thing that I have seen to that "T" nut and washer was something a representative of a hardware supply company demonstrated at a car show, it was an insert that you could use in sheet metal to hold a machine screw. I don't know what the proper name of these inserts is but the device he used was something like a pop riveter that would expand part of it so it would not come out. If I remember I will go down to their store and ask them about them.
P.S The cabinet top is warping because there is veneer on the bottom side, which is also still sealed, but none on the top. So the boards that make up the cabinet top can absorb moisture and dry out faster on the side where the veneer was removed. When you re-veneer the top and seal it again it should stop doing that, but to flatten it out just wipe it down with a damp rag and clamp it first.
arron
their is a tool called nut-insert looks like pop rivet gun
you screw a post in an then nut-insert squeeze handle.  bends top over a little
easy said then done
buzz  if you want to try it I will loan you mine
great job on potatoes  Icon_clap Icon_clap     johns a sore looser Icon_e_wink
sam
(08-08-2015, 11:51 AM)sam Wrote:  arron
easy said then done
sam
Thanks guys for your suggestions, but I've figured a way to do it. Watch next Fridays video as I will show in detail....Buzz
PS ,,I think John learned the real way to grow potatoes from me..haha
(08-08-2015, 03:26 AM)Arran Wrote:  Buzz;
Good explanation as to the warping...It was very hot in the garage and muggy....thanks, buzz
Hello Phorum:
Part 7 of my 1939 Stromberg Carlson 430-H series now uploaded.
https://www.youtube.com/watch?v=B0eMxAwTC2A
buz
hmm what happen to 1157 ?
great video as always Icon_clap Icon_clap
that screw driver is that for the philco centric cone alignment
if so can I get a close up of it
thanks sam
Another great video Buzz!
You sure are getting a lot of use out of that pencil sharpener  Icon_wink
The speaker table error?
Philco 70 antenna lead
