1939 Stromberg Carlson 430-H Restore on YouTube
#31
(08-15-2015, 01:30 PM)sam Wrote:  buz
hmm what happen to 1157 ?
great video as always Icon_clap Icon_clap
that screw driver is that for the philco centric cone alignment
if so can I get a close up of it
thanks sam
Its always been 1151...
I believe I did make that for my philco 38-7..Just used a dremel tool to make it
Dont remember if it worked that well..
#32
(08-15-2015, 01:54 PM)Eliot Ness Wrote:  Another great video Buzz!
You sure are getting a lot of use out of that pencil sharpener  Icon_wink
yes i am  Icon_clap
#33
I like the way you tap that pencil! With authority!
Crist
#34
(08-16-2015, 01:00 AM)Crist Rigotti Wrote:  I like the way you tap that pencil!  With authority!
Yes...My sharp pencil gives me super powers..haha...buzz
#35
Hello Phorum:
Part 8 of my 1939 Stromberg Carlson 430-H series now uploaded.
A link below is for anyone interested...thanks
https://www.youtube.com/watch?v=ZDS6KNOZxuo
#36
Hello Phorum:
Part 9 of my 1939 Stromberg Carlson 430-H series now uploaded.
https://www.youtube.com/watch?v=cI5PrJYtfw4
#37
great work so far Icon_clap Icon_clap   keep them coming  thanks for posting Icon_thumbup
sam
I've read mixed reviews on the Peel and Stick veneer so it will be interesting to see how well it holds up for you.
Clever movie tie-in with Dickel and I also enjoyed the bumper sticker!
Thanks again Buzz!
(08-30-2015, 01:24 PM)Eliot Ness Wrote:  I've read mixed reviews on the Peel and Stick veneer so it will be interesting to see how well it holds up for you.
Thanks again Buzz!
thanks Eliot  for your support...buzz
#40
Thanks again Buzz!
 I've never read any reviews about peel an stick veneer, but I can imagine three obvious potential problems give what happens to other peel and stick products.
(A) The glue will ooze out or off gas from time to time causing problems with the finish.
(B) The glue will dry out causing the veneer to detach itself.
© The glue will allow the veneer to shift around with changes in heat and humidity.
Aside from those, and given the situation with paper backed veneer, the selection of different cuts and species will be limited to the more common types.
Hello Phorum:
Part 10 of my 1939 Stromberg Carlson 430-H series now uploaded.
https://www.youtube.com/watch?v=YyueqFODBbA
#42
Coming along quite nicely Buzz.  Your flocking sure turned out nice as did the trick with the gold Sharpie.  Your videos are a great mix of humor and technical.
buzz
who`s the blonde singer on last video
sam
(09-12-2015, 03:19 PM)sam Wrote:  buzz
sam
Betty Hutton
https://www.youtube.com/watch?v=ClGNm89GZBE
Crist
#45
Hello Phorum:
Part 11 and FINAL part of my 1939 Stromberg Carlson 430-H series now uploaded.
https://www.youtube.com/watch?v=1wNGFOShNms
Users browsing this thread: 13 Guest(s)
The speaker table error?
Philco 70 antenna lead
