My new 53-960. Needs recapping, and restringing.
But sounds awesome as it is! I've ordered a schematic from Steve Johnson. I may order one from Philco Repair Bench, but am unsure whether they might have one for this model.
Icon_clap Icon_thumbup
You will enjoy that set! It is as good a performer as it is visually stunning. That is the last really great radio Philco ever made.
Very nice, congratulations Icon_thumbup
I think that's the one I almost bid on, but now I'm glad I didn't because radios are a lot scarcer for you than for us here in the states.
Any idea where I might find a knob? I believe it's the one for the Radio/Phono switch is broken (they've put tape around the shaft).
Mike Koste, gobs of knobs? He posts here with his name backward, usually Ktown Info, he is mbr DVHRC.
There are currently 5756 online users. [Complete List]
» 1 Member(s) | 5755 Guest(s)
