1939 Stromberg Carlson 430-H Restore on YouTube
Threads: 60
City: Portland, Oregon
08-15-2015, 02:39 PM
(08-15-2015, 01:30 PM)sam Wrote: buz
hmm what happen to 1157 ?
great video as always
that screw driver is that for the philco centric cone alignment
if so can I get a close up of it
thanks sam
Its always been 1151...
I believe I did make that for my philco 38-7..Just used a dremel tool to make it
Dont remember if it worked that well..
Threads: 60
(08-15-2015, 01:54 PM)Eliot Ness Wrote: Another great video Buzz!
You sure are getting a lot of use out of that pencil sharpener
yes i am
Threads: 22
City: Waxahachie, TX
I like the way you tap that pencil! With authority!
Crist
Threads: 60
(08-16-2015, 01:00 AM)Crist Rigotti Wrote: I like the way you tap that pencil! With authority!
Yes...My sharp pencil gives me super powers..haha...buzz
Threads: 60
Hello Phorum:
Part 8 of my 1939 Stromberg Carlson 430-H series now uploaded.
A link below is for anyone interested...thanks
https://www.youtube.com/watch?v=ZDS6KNOZxuo
Threads: 60
Hello Phorum:
Part 9 of my 1939 Stromberg Carlson 430-H series now uploaded.
https://www.youtube.com/watch?v=cI5PrJYtfw4
Threads: 337
City: lawrenceville nj
great work so far  keep them coming thanks for posting
sam
Threads: 55
City: Lexington, KY
I've read mixed reviews on the Peel and Stick veneer so it will be interesting to see how well it holds up for you.
Clever movie tie-in with Dickel and I also enjoyed the bumper sticker!
Thanks again Buzz!
Threads: 60
(08-30-2015, 01:24 PM)Eliot Ness Wrote: I've read mixed reviews on the Peel and Stick veneer so it will be interesting to see how well it holds up for you.
Thanks again Buzz!
thanks Eliot for your support...buzz
Threads: 54
Thanks again Buzz!
I've never read any reviews about peel an stick veneer, but I can imagine three obvious potential problems give what happens to other peel and stick products.
(A) The glue will ooze out or off gas from time to time causing problems with the finish.
(B) The glue will dry out causing the veneer to detach itself.
© The glue will allow the veneer to shift around with changes in heat and humidity.
Aside from those, and given the situation with paper backed veneer, the selection of different cuts and species will be limited to the more common types.
(This post was last modified: 08-31-2015, 04:37 AM by Arran.)
Threads: 60
Hello Phorum:
Part 10 of my 1939 Stromberg Carlson 430-H series now uploaded.
https://www.youtube.com/watch?v=YyueqFODBbA
Threads: 55
City: Lexington, KY
Coming along quite nicely Buzz. Your flocking sure turned out nice as did the trick with the gold Sharpie. Your videos are a great mix of humor and technical.
Threads: 337
buzz
who`s the blonde singer on last video
sam
Threads: 22
(09-12-2015, 03:19 PM)sam Wrote: buzz
sam
Betty Hutton
https://www.youtube.com/watch?v=ClGNm89GZBE
Crist
Threads: 60
Hello Phorum:
Part 11 and FINAL part of my 1939 Stromberg Carlson 430-H series now uploaded.
https://www.youtube.com/watch?v=1wNGFOShNms
The speaker table error?
G 10-1/2" 65, 76, 87, 95
Push-Pull 45's
2766
0.7
550
3200
H 10-1/2" 77, 96
Push-Pull...morzh — 09:26 PM |
I have a Stromberg, one of the early ones, seems early 30s.
This is what I call a back breaker. None of the early Philc...morzh — 08:28 PM |
A backbreaker.....PaulPaul Philco322 — 08:12 PM |
>>What a behemoth!
A Juggernaut.morzh — 07:47 PM |
Philco 70 antenna lead
I am not sure I understood about the coils and the mush. I looked an more than one coil in 20, 70, 90, 60, Zeniths and ...morzh — 07:46 PM |
:e_biggrin: What a behemoth! I hope the final result is as much a quality sounding example! Keep us posted on your pro...GarySP — 07:32 PM |
I should add that the double conversion may only be used on the shortwave bands, but I haven't looked at the schematic t...Arran — 07:27 PM |
Yes, that wire will not pick up much interference as routed - the RF at that level won't be affected, and if you have st...radio1 — 07:26 PM |
I'm also a member of MARC. Did you attend the Vintage Electronics Expo in Waterford, MI last month? That's where I got...GarySP — 07:22 PM |
Dan
Double conversion is using two IF converters instead of one. This improves the image response.
morzh — 07:15 PM |
