Philco 60B Restoration
#31
I applied the trim color today. I went with Perfect Brown toner but I thought it could be a little darker, so shot a couple of light coats of Extra Dark Walnut. The color is now a deep brown, not black, but darker than a solid brown.
One thing that I noticed is that on the front where I masked off the bottom trim, when I pulled off the tape, there is a definite lighter area where the tape was. Any good ideas as to how to fix that?
[Image: http://i1060.photobucket.com/albums/t458...q9rscy.jpg]
[Image: http://i1060.photobucket.com/albums/t458...mytjsj.jpg]
Crist
#32
Going with the grain (Gently) rub some very fine steel wool over that area and it should blend in the tape line, do it very ( Icon_wave gently) Icon_wtf Icon_wtf Icon_wtf Icon_wtf Icon_wtf Icon_wtf Icon_wtf Icon_wtf Icon_wtf
#33
(08-28-2015, 09:03 PM)Frederick W. Taylor Wrote:  Going with the grain (Gently) rub some very fine steel wool over that area and it should blend in the tape line, do it very ( Icon_wave gently) Icon_wtf Icon_wtf Icon_wtf Icon_wtf Icon_wtf Icon_wtf Icon_wtf Icon_wtf Icon_wtf
10-4
Crist
#34
Here is the cabinet after I shot a couple of coats of Mohawk E-Z Vinyl Sealer. I wish I would have done a better job with the grain filler. oh well, not bad for the first one though.
[Image: http://i1060.photobucket.com/albums/t458...ujm1s5.jpg]
[Image: http://i1060.photobucket.com/albums/t458...1gnlpj.jpg]
Crist
#35
Looks mighty fine so far Crist.
Jerry
#36
(08-30-2015, 05:49 PM)jerryhawthorne Wrote:  Looks mighty fine so far Crist.
Jerry
Thanks Jerry!
Crist
#37
Looking good Crist, don't for get your Philco decal before you start clearing, and you need to sign it also before clearing, your a true artist Icon_wtf Icon_wtf Icon_wtf Icon_wtf Icon_wtf Icon_wtf
#38
(08-30-2015, 07:18 PM)Frederick W. Taylor Wrote:  Looking good Crist, don't for get your Philco decal before you start clearing, and you need to sign it also before clearing, your a true artist Icon_wtf Icon_wtf Icon_wtf Icon_wtf Icon_wtf Icon_wtf
Thanks Fred.  I was going to shoot maybe 5 coats of clear then add the decal.  Would that be ok?
Crist
#39
Sneak peek! I still have to shoot the clear topcoats yet, but I couldn't resist.
[Image: http://i1060.photobucket.com/albums/t458...jrbjsu.jpg]
[Image: http://i1060.photobucket.com/albums/t458...8ymagf.jpg]
Crist
#40
Hello Crist, 2 coats of clear would be enough. The more clear over decal the better , it will hide the cut line on decal better. I really like that EZ lacquer vinyl sealer from mohawk, it tends to fill better than there regular sanding sealer and is alot more durable  . Now just sand lighly with 400 and shoot 2 coats of the buffcoat .
#41
OK, I think I'll shoot the topcoat clear tomorrow.  Getting close!
Crist
#42
I put on the decal before any top coat was sprayed. I then sprayed on 2 wet coats of Mohawk Buffcote sheen 40 thinned about 60% top coat and 40% Mohawk reducer. When those coats were dry, I lightly sanded then cabinet and then shot 4 more coats. The cabinet is finished. I'll take better pictures later.
[Image: http://i1060.photobucket.com/albums/t458...d1bhmq.jpg]
[Image: http://i1060.photobucket.com/albums/t458...uwfond.jpg]
[Image: http://i1060.photobucket.com/albums/t458...cpepls.jpg]
Crist
#43
Looks perfect Crist! Very nice job.
jerry
#44
Very nice Icon_thumbup   Icon_clap   Icon_thumbup
  Great job Crist. I have followed your thread from the start. You did a lot of work and it has payed off.
Users browsing this thread: 15 Guest(s)
There are currently 10587 online users. [Complete List]
» 3 Member(s) | 10584 Guest(s)
