The Z Bomb
This is just a little drawing I whipped up to help advertise the serious power lurking inside the Zenith 8-S-563. I drew this completely freehanded in about half an hour. The lighting is two 40 watt mercury vapor lamps.
Slave to an RCA Victor CTC-25
(09-02-2015, 10:57 PM)TheUniversalDave1 Wrote:  This is just a little drawing I whipped up to help advertise the serious power lurking inside the Zenith 8-S-563. I drew this completely freehanded in about half an hour. The lighting is two 40 watt mercury vapor lamps.
Where is the mushroom cloud? Icon_eek Icon_eek Icon_eek Icon_eek Icon_eek Icon_eek
I already fanned it away for the picture.
I actually understood this!!!!
I am learning, Icon_lol
You need practice..... or a ruler Icon_mrgreen
Me
If you understand it can you explain it to me, please? Because I have no clue what it means.
Yes Lucy explain!!
Really?
I'M the smart one??????
Hold H**l, Mark your calenders!
A Mercury vapor lamp is meant to burn much brighter than a standard bulb. Especially high pressure lamps.
Are these new bulbs? These bulbs need a burn in period when first lit. At least an hour and they can be brighter in the beginning. They can burn 10-100 times brighter.
Another thing can be the Ballast having an issue.
This is not set up as a Dim bulb tester right? If that is the case then there may be a short in the DUT but I am pretty sure in a darker room with light walls it is just the bulb.
Now watch me be wrong and get blown out of the water Icon_lol
Me
This fixture has been working fine for a year and a half.
The two light globes look like....you know what. Icon_smile
The speaker table error?
Philco 70 antenna lead
There are currently 2970 online users. [Complete List]
» 2 Member(s) | 2968 Guest(s)
