FOMOCO Radio
That's the antenna trimmer screw.  It usually winds up being screwed in clockwise almost all the way for best reception.  Make sure you have a good antenna connection.  The screw is adjusted by finding a weak station around 1400 and adjusting to maximum volume.  Your radio, however, may be on the fritz.
Craig R
(09-14-2015, 02:12 PM)VntgRads Wrote:  That's the antenna trimmer screw.  It usually winds up being screwed in clockwise almost all the way for best reception.  Make sure you have a good antenna connection.  The screw is adjusted by finding a weak station around 1400 and adjusting to maximum volume.  Your radio, however, may be on the fritz.
Craig R
I checked my stereo AM stations (on my old Pioneer SX-828 receiver from the 70s) to find a station around 1400.  Found one at about 1430, but can't get anything on the Ford radio.  Do you repair these?
No, I don't do the electrical but just the mechanical/cosmetic portion.  You might want to hold off until you find the proper '68 radio for your car.
Craig R.
I’ve consulted a couple of the books which I got from Jim Koehler, Elements of Radio Servicing (Marcus and Levy, 1947) a...jrblasde — 10:58 PM
Gloritone 27 Radio
Richard, Radiotrope was one of the many nameplates coming out of the Marion, Indiana U.S. Radio and Television Corp plan...Eliot Ness — 10:12 PM
[split] New member...
Oh... That link is gold man! Thank you so much. I'll see if I can get this thing fixed and will post the results on...HowardWoodard — 08:10 PM
Gosh. I always re-discovered how to do it, took me 2-3 minutes every time. Now that I think of it, the c-clip is there b...morzh — 07:17 PM
38-690 Gill Cloth
Yeah, this one is not a chevron pattern. Ask Mike Katz, if he has something that is similar.morzh — 07:02 PM
38-690 Gill Cloth
Hi Folks, Is anyone currently selling a good reproduction of the 38-890 grill cloth? Thanks Stevetargeteye — 06:57 PM
@morzh: As you can see from the pics I included, there is no clip where the vernier shaft comes out of the brass coarse ...HowardWoodard — 06:56 PM
I think where the shaft comes out of the brass piece, there should be a clip.morzh — 06:47 PM
Well, you're right but the AVC gets to the control grid through the IF secondary, no direct connection to the control gr...RodB — 06:36 PM
Where do I look? 7B7 Suppressor? Both these radios seem to connect the SG to AVC. Which I am not sure why, but then ...morzh — 06:27 PM
