Philco 116B Dial Escutcheon/Glass Dial Cover
I have a 116B that needs a dial escutcheon/dial glass cover. I saw one for sale for a Philco 645. Are these interchangable? They both appear to hav a shodow meter.
Thanks!
Allen
No, they are not the same. The 116 requires a larger (taller) escutcheon than the 640.
Thank you Ron, you just spared me from buying the wrong escutcheon. Are there other models that use the same size escutcheon as the 116B?
Thanks!
Allen
Only the following use the escutcheon you need:
116, 660, 665, 680.
Ron:
Very helpful. As always, I appreciate your time and extensive knowledge.
Allen
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
