Mystery control warping
My dialer on the mystery control is slightly warped - did anyone ever try to straighten one? Maybe by heating to a certain temp. and then pressing it between clamps and cooling it ? Any other ideas?
Thanks
Tom
I doubt you can--it's made of tenite, and that stuff shrinks and warps by nature.
It's been done, and apparently successfully, too. Details here:
http://www.philcoradio.com/tech/myscon.htm
Cool! I'll have to remember that trick....
Philco 91 Tuning Condenser
There are currently 9818 online users. [Complete List]
» 1 Member(s) | 9817 Guest(s)
