Threads: 367
City: Dover, OH
(This post was last modified: 09-28-2015, 05:07 PM by Jayce.)
Threads: 337
City: lawrenceville nj
very cool looking radio good luck
Threads: 40
City: Sanger, CA
Threads: 416
City: Boston
That is very cool styling, do you know the house that made it for Sears? I almost bit on a small size Silvertone console this weekend, of course I had no room for it so I am surprised I did not buy it!
Good luck, that set is a looker.
Threads: 367
City: Dover, OH
Hmm, not sure who made it for Sears, but it is a nice design for sure. Got some very good news. After cursing and swearing for a bit tonight, I was finally able to use a jumper to bypass that off-on switch and we had power! The radio passed the transformer test my late friend taught me and then I brought it up slowly, actually getting our local station in fairly loud and clear. Both speakers seem to work, the motor tuner is still alive, though slips in spots like the manual tuning. I'm getting excited as this radio is showing very good signs and it already has a nice sound to it. Might become my daily driver once rebuilt.
Threads: 114
City: Sneedville, TN
I am really looking forward to following your progress with this radio. Please post often as you work on it with pictures to illustrate important steps or details. Best of luck, that is a marvelous radio !
Threads: 367
City: Dover, OH
Just found out that Colonial built this unit for Sears. Seems they built the lion's share of the radios for Sears before the war and it seems Crescent took over in the late 40's for a bit. I basically have the top of the line prewar Silvertone now and the top of the line Postwar Silvertone.
Threads: 2
City: Southport NC
I believe the 6 digit code Silvertone used is 100.XXX for the radio which would make it a Stewart Warner build.
Here we go
http://www.radiomuseum.org/r/sears_roeb_4688.html
Scroll down to numeric list here
http://www.radiomuseum.org/forum/silvert...ogs.html#3
Just a guess but Ill bet that chassis isn't too far away from this beast
http://antiqueradio.org/StewartWarner1865Radio.htm
Lotta good info for you there^^^
(This post was last modified: 09-28-2015, 02:17 PM by JimZ.)
Threads: 3
City: Albuquerque, NM
I believe the model you have there is a 4788. Jim Z is correct as this is a Stewart Warner manufacture. Notice the difference in the cabinet you have versus the 4688. I would say the cabinet is a step up from the 4688. Quite a find.
John
Threads: 367
City: Dover, OH
Stewart Warner is even better! My friend might have gotten confused. Hmm, a 4788? I think mine has 4688 stamped into the back of the cabinet. Now I will have to go check. Pulled the chassis and.. broke a dial cord! Managed to replace it using some string from a cat litter bag of all things! I did find out something though, dial cords are a pain! Pictures and more info to come soon.
Edit: Yep, it IS a 4788! Need to download another schematic and change the title of this thread.
(This post was last modified: 09-28-2015, 04:45 PM by Jayce.)
Threads: 2
City: Southport NC
I know there is some variation with cabinets..I remembered from a "shorty" Kirk found some months ago.
In the thread youll see the versions I found..not that it matters a whole lot.
http://www.antiqueradios.com/forums/view...1&t=275342
Threads: 367
City: Dover, OH
Looked at my schematic again. Seems mine is right smack in the middle. There was a 4688, a 4788, and 4799 listed on the schematic I found.
Threads: 2
City: Southport NC
Before you know it? Youll be seeing this(with your cabinet)
http://i213.photobucket.com/albums/cc249...1323381898
(This post was last modified: 09-28-2015, 06:28 PM by JimZ.)
Threads: 416
City: Boston
Stewart Warner, nice....................
Threads: 367
City: Dover, OH
It might be a little bit before the unit is going. For one thing, the power-volume control is totally shot. That will need replacing. Luckily all the gearing on the tuner is intact and looks better built than the RCA and GE variants. Probably good as everything, including the manual tuning drives through the motor and the gears. I did find what my tuning issue is though, a rubber cone on the end of the motor shaft. Of course, it's burried in there! Any ideas how to repair this issue? Even the manual tuning needs this:
And, here are a couple more pictures of the chassis removed:
Dan;
I've seen some Marconi sets like that before, one was a console though I'm not sure if it was a model 86. It's a...Arran — 05:09 PM |
Milkjug plastic?
Whatever is chosen for the spider, the material must be compatible with popular adhesives...
Th...Chas — 05:05 PM |
Mike;
I would not use plastic from a milk jug for a spider, first it's polyethylene/polypropylene which resists most ...Arran — 04:56 PM |
This is my thread on 60 from 2016.
I had to rewind the osc coil, and I actually counted the turns and then rewound i...morzh — 03:34 PM |
Yes, Mark belongs to the same Michigan Antique Radio Club that I do. I suspect that the oscillator coil is in need of a ...Radios1340 — 03:10 PM |
Yeah. I am dreading the thought of what to do with all my consoles when I will no longer be able to move them around.
I...morzh — 02:51 PM |
Cool gadget, Buzz.
I took me a couple of second to undestand that that oscillating thing makes the wire to spool correc...morzh — 02:50 PM |
My back hurts already, you could build a house with all the wood. PaulPaul Philco322 — 02:49 PM |
Part 4 of this series now uploaded
link below to anyone interested
Buzz — 02:39 PM |
Welcome to the Phorum, Radios1340! The oscillator coil on the 60 is a common culprit. I just bought a 60B (June 1934) ...GarySP — 02:33 PM |
There are currently 4947 online users. [Complete List] » 2 Member(s) | 4945 Guest(s)
