Philco 37-630
I just bought a gorgeous Philco 37-630, from the original owner. Can someone tell me what the different function knobs are for. There are 4 knobs total. Which is for what function? Thanks, Phil
Sure, here you go:
TUNING (double concentric knobs just under the dial)
The other three are, left to right: OFF-ON-TONE, BAND SWITCH, VOLUME.
Ron: Thanks.....Phil
There are currently 8565 online users. [Complete List]
» 1 Member(s) | 8564 Guest(s)
