My latest find
   I hope I got this in the right section.. here is my latest Philco. It is a model 37 3650 console.. The cabinet is in good condition  but I always have a challenge with those Bakelite blocks. It will be a winter project.  I will be looking for the small outer tuning knob and one of the other knobs.
   Living in Calgary Alberta
Nice find there. I like the looks of the 1937 Philco consoles. Just don't like the unitized chassis..
Nice radio, and seems in nice shape for restoring. I looked at the schematic and it looks like a really fine set. With a stage of TRF before the mixer it is going to have good sensitivity and selectivity. Great find ! I look forward to following your progress.
Sweet! That's radio is very CLEAN! Most of the ones I find are full of dust and bugs. Good score!
Slave to an RCA Victor CTC-25
I can't be sure from your photo, but I think you can find repro knobs to match at Renovate Radios.
John Honeycutt
Nice find! It is a nice looker
me
A nice example of an excellent Philco 8-tube set.
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
