Can anyone please help me ID this radio.
I just picked this up from a Craigslist add tonight. It was listed as a Philco and has Philco tubes inside but no other paperwork or model number stamping anywhere. There is also a "extra" speaker that plugged into the side that is also stamped Philco with its own volume knob.I'll get some more pictures up over the weekend.
Definitely not a Philco; it is an RCA. Possibly a 9K chassis in a homemade cabinet.
Thank you so much! Here is a few other pictures.
The speaker table error?
Philco 70 antenna lead
