Threads: 6
City: Lakewood, Ca 90713
I don't know if this has been ever discussed before.Was there ever a Philco model that had one?
Was there a reason for them not using the concept? With such a wide range of models and spanning
many years of production. Just surfing through Radioattic and RM I don't see a single one. Although I
could be wrong.
Your thoughts or observations,or facts as to why or why not.
Thanks, Doug
Threads: 69
City: Kansas city, MO.
I believe this came up quite awhile back and I think the response I seen said that Philco did not ever use eye tube.
Philco used the shadow meter. I don't know reason why they never used eye tube.
I think there was at least one 1950s Philco, made in the UK, that had a European tuning eye tube. No, no domestic (USA) Philco models used them. Philco had shadowmeters from 1932 through 1938. RCA was a hated enemy as far as Philco was concerned.
Ever surf through the Philco radio gallery?
Threads: 6
(10-17-2015, 10:08 PM)Ron Ramirez Wrote: I think there was at least one 1950s Philco, made in the UK, that had a European tuning eye tube. No, no domestic (USA) Philco models used them. Philco had shadowmeters from 1932 through 1938. RCA was a hated enemy as far as Philco was concerned.
Ever surf through the Philco radio gallery? Hi Ron,
Yes I have many times from top to bottom. Stupid me for not referring to the Gallery ![Icon_redface Icon_redface](https://philcoradio.com/phorum/images/smilies/icon_redface.gif) That would be the most likely
place to have gone. Working on my Monster 16B cathedral and replacing all the bakelite caps and resistors, love that tar. ![Icon_biggrin Icon_biggrin](https://philcoradio.com/phorum/images/smilies/icon_biggrin.gif) 7 out of 13 done.Wouldn't know what to do without the 2 page service bulletin #289 for the cross reference.
Already replaced the electrolytics and it is surely sounding better with every cap change.
Threads: 54
I was just about to say that if a Philco model even used a magic eye tube it wasn't a U.S or Canadian made model, though some Canadian models may have had a tuning light since some of the Tropic models did, other then that it was shadow meters from 1932-38. I don't know if it had anything to do with RCA since Allan B. DuMont was the guy who invented them or if it was because they came out in 1935 and Philco was already equipped to produce shadow meters in house and couldn't see the point in switching to magic eye tubes that did the same job? Philco was a company that liked generating economy of scale, so maybe it was less expensive to use in house built shadow meters then it was to buy magic eye sockets, and tubes, and royalties to use them?
(This post was last modified: 10-18-2015, 04:29 AM by Arran.)
Arran - RCA produced the tuning eye tubes, and promoted the heck out of them.
There is no doubt that Philco knew how to pinch pennies wherever it could. You can thank Jim Skinner for that.
Brand Z also used shadowmeters in the early 1930s as did a few others, including Atwater Kent, I believe. I find it interesting that Zenith came out with "Target Tuning" for the 1937 season which, if I'm not mistaken, was a variation of a shadowmeter? And then for the 1938 season, they used the 6T5 eye tube made by Sylvania to Brand Z's specs. I am sure the 6T5 was an expensive endeavor which is why they ultimately switched to the standardized 6U5.
Threads: 114
City: Sneedville, TN
Yes, Ron, I have an old Z brand highboy console, a 410 from 1933, like this, http://www.radioatticarchives.com/radio.htm?radio=6019 , that uses a shadow type tuning meter. It has a solenoid type set up with a coil, and a center slug that is drawn inward as the current through the coil increases and increases its magnetism. This internal slug is in turn connected to a little metal vane that turns and causes light to shine in a wider or narrower band on a translucent screen, much like Philco's set up.
Threads: 2
City: Southport NC
Heres a pretty good illustration/data on all the various methods
http://www.radiomuseum.org/forum/history...e_led.html
My personal favorite is these. Man what a dial
http://www.radiomuseum.org/r/ingelen_us26w.html
Gary
I in fact did, on a 38-14, I think, where I had a speaker with the dead coil.
Well...it kinda worked. Kinda, be...morzh — 10:38 PM |
Mike, what ever happened to that plan you had to try using a rare earth magnet to magnetize the pole? This looks like a...GarySP — 10:25 PM |
RCA T62 is playing.....
Beautiful set.morzh — 09:07 PM |
Well....here it is.
The green stuff. Unfortunately, probably penetrates deep.
I opened the top layer and saw that:
...morzh — 08:58 PM |
Philco 91 Restore Code ??
:clap: :clap: :clap: :clap:
Really nice workmanship!!! Top of the chassis looks great.
Sorry about the long winded e...MrFixr55 — 08:09 PM |
Philco 40-120C Restoration
Thank you for your reply. I will check voltages on the other tubes, look at resistor 23 and cap 25, etc. If all else fai...bluecap — 07:58 PM |
Nice looking set great save. DavidDavid — 07:48 PM |
Philco 89 indicator light.
Hello Jim, I have done several 89s. The trick is to move the drum in or out on it's shaft. You will need to loosen a set...dconant — 07:36 PM |
MrFixr
Yes, it is my plan to go with 45rpm spider if I go that far.
No, the pole was not left-handed as I unscrewed ...morzh — 07:14 PM |
Change the tube. Check the tube's bias network.
Are any other tubes experience the drop or just this?`
Is resistor 23 OK...morzh — 07:09 PM |
