Silvertone 4788 Help
I need help with the tuning drive on my Silvertone 4788. It uses a rubber drive cone that is crumbled and a bit hard to get to. Doesn't help that it is rubber bonded to a metal cone.
I'd get the thing out and have a good look at it. Measure the dia and see what you can scare up at the local hardware store. They have lots of goodies in sliding drawers there. Maybe a large chassis grommet would fit the bill clean off the old rough up the metal a bit and use some super glue to hold it on.
 +1 to Terry's advice.
The hardest part will be getting it out.  You'll just have to slowing start taking it apart until you can get it out.  Make a lot of notes/drawings and take a lot of pictures so you'll know how it goes back together.
Jayce, I had a radio with a friction drive and the rubber was shot. I used a faucet washer (conical) and with a little rework on the washer it worked fine.
Jerry
Dan; I've seen some Marconi sets like that before, one was a console though I'm not sure if it was a model 86. It's a...Arran — 05:09 PM
Milkjug plastic? Whatever is chosen for the spider, the material must be compatible with popular adhesives... Th...Chas — 05:05 PM
Mike; I would not use plastic from a milk jug for a spider, first it's polyethylene/polypropylene which resists most ...Arran — 04:56 PM
There are currently 6003 online users. [Complete List]
» 2 Member(s) | 6001 Guest(s)
