Decal sizes for these models
I want to get the decals for my radios all at once so I am wondering what size labels go on these radios?
I am not sure if all of these have decals but no pressure. I can measure them if no one knows.
Any help is appreciated.....Ron, Icon_lol
6. Philco 14LZX and speaker cabinet
7. Philco 19 LZX and speaker cabinet
14. Philco 37-610 early
15. Philco 37-610 Late
16. Philco 37-610 Late (2)
17. Philco 38-23X
18. Philco 40-145
19. Philco40-145T
22. Philco 45
23. Philco 60B
24. Philco 60B Late
25. Philco 66
27. Philco 70
28. Philco 71B
29. Philco 604
For all save the 1937, 1938 and 1940 models on your list, you want to use DCL-PH8.
Let me check tonight as to the others. Kindly remind me if I forget.
The 14LZX and 19LZX speaker cabinets have no decals. Only the control units have the PHILCO trademark.
Okay!
For your early 37-610: It may also use DCL-PH8...or it may use the medium sized PHILCO on the DCL-PH1 sheet.
Measure your old one to be sure!
DCL-PH1 and DCL-PH3 have the correct PHILCO font for 1937 and later Philco models.
Some early production 1937 Philco cabinets still used the DCL-PH8 style. Compare what is on your 1937 cabinets to the above decal sheets to be sure what you need.
For your late 37-610 and 38-23X: Depending upon how long the originals are, probably one of the medium sized decals on the DCL-PH1 sheet.
For your 40-145: Probably the smaller decals on the DCL-PH1 sheet. Again, measure to be sure.
Whatever you do, please do not buy the DCL-PH7 or DCL-PH9. The fonts are entirely wrong, and I do not know why they are still selling these inaccurate decals. Icon_rolleyes
Wow Ron,
Thanks much!
I will order the correct ones now!
Me!
Oops...make that the medium decal on the DCL-PH1 sheet for the 40-145 as well...I think. Icon_crazy Again, measure to be sure.
There are currently 11401 online users. [Complete List]
» 2 Member(s) | 11399 Guest(s)
