Can anyone ID my Philoc speaker/AOT?
Hi all, I have a 5" Philco speaker (2.7K ohms field) with a Philco 32-7020 output transformer (single stage) riveted to it. I have not been able to trace this part number. Can any Philco experts help me out and trace this back to whatever radio it originally came from? Thanks,
Ted
Courtesy of Ron.  Speakers.zip file.
Try here.
http://www.philcoradio.com/phorum/attach...p?aid=5181
(11-06-2015, 01:17 PM)OZ4 Wrote:  Courtesy of Ron.  Speakers.zip file.
Try here.
It's from the model 54  using a single 43 output.
                         Henry
Restoring Philco 96
There are currently 7779 online users. [Complete List]
» 2 Member(s) | 7777 Guest(s)
