Fisher X-101-D or Eico ST 70
So I need your opinion on which one should I keep. Both have 7591 output tubes but the Fisher I believe has a built in multiplex, correct me if I'm wrong. I will provide pictures soon, having some issues with photobucket.
pictures i hope ! of the Fisher[Image: http://i1281.photobucket.com/albums/a508...jgzw4j.jpg]
[Image: http://i1281.photobucket.com/albums/a508...wcxbde.jpg]
And pictures of the Eico that i have already finished the rebuild, and it sounds fantastic. So someone tell me will the Fisher perform better.[Image: http://i1281.photobucket.com/albums/a508...lhiqjb.jpg]
[Image: http://i1281.photobucket.com/albums/a508...sqaybd.jpg]
I've had both and I'd keep the Fisher. No multiplex in the Fisher as a MPX is used in a tuner or receiver. The X-101-D does have a strange bias set up but it's a great sounding amplifier.
You'd probably get more $ for the Fisher (if both restored,) but probably not a whole lot of difference otherwise.
Well i tried to sell the Fisher and no takers, so i'm keeping it and selling the Eico. The Eico is restored and the Fisher is not but i will remedy that real soon. Thanks everyone for the input and suggestions.
Eico 232 VTVM Schematic
There are currently 6513 online users. [Complete List]
» 2 Member(s) | 6511 Guest(s)
