1936 116-122 Cabinet Restoration
Very nice  Icon_clap
I will be going to Staples and getting copies as the paper is 11x14. I will gladly shoot you one or if you want just a file to play with and try to clean it up I can do that too!
(11-12-2015, 01:02 PM)OldRestorer Wrote:  Very nice  Icon_clap
Thanks.
Both would be nice if you can.
Thanks again.
Crist
Ok,
  I went and got them scanned. I printed the 116X ad but it is unedited.
I edited them today so if you message me your email addy I can send the high resolution scans of the originals and fixed up ad's.
The second one is the original instructions for the Philco 70.
Anyone who wants them please message me with your email addy. Do not copy the ones below. They will lose a ton of resolution and clarity.
I cant get the philco 70 paper to load!
Me
Some very light sanding and then the clear top coats! The trim is Extra Dark Walnut.
[Image: http://i1060.photobucket.com/albums/t458...pmq0vs.jpg]
Crist
Wow,
That made a big difference in the look! So deco right now. I may need one of these and it will be your fault, Icon_lol
Me
(11-13-2015, 06:07 AM)OldRestorer Wrote:  Wow,
Me
Thanks.  I got the scans.  Thanks again.
Crist
I did the grille cloth today and just couldn't resist a sneak preview.  I have to sand the sealer coats then on to the final top coats.  Getting close.  It'll be ready in a few weeks.
[Image: http://i1060.photobucket.com/albums/t458...bpbmai.jpg]
[Image: http://i1060.photobucket.com/albums/t458...efuxf8.jpg]
Crist
Still need some information. I'm hoping someone here can help.
I concerns the small tan colored plastic piece that goes between the dial glass and the shadow meter. When I got this radio, this piece was missing. Does it attach to the back side of the dial glass or to the front side of the shadow meter? Regardless of where it goes, how does it get attached? any help especially pictures would be appreciated.
I did a search and came up with nothing. I'll do another search in the mean time.
Thanks.
Crist
I found a picture of the backside of the dial glass and it had the tan colored piece of plastic on it. Looking at mine to appears that it was tack glued on the backside of the glass. The plastic is trapezoid shaped.
Now I'll have to cut up an old discarded dial scale to make one up.
Crist
Here's a picture of how it is shaped and attached.
[Image: http://i1060.photobucket.com/albums/t458...kcatfr.jpg]
Crist
No sneak peeks buddy!
You want the full satisfaction of seeing it when it is all finished and gleaming.
Now you must work with your eyes closed until finished.
Icon_mrgreen
That's the same plastic that's used on the dial, cut a piece off old dial to fit in its place Icon_eek
All done!
[Image: http://i1060.photobucket.com/albums/t458...q3h6zp.jpg]
[Image: http://i1060.photobucket.com/albums/t458...1gz8ca.jpg]
[Image: http://i1060.photobucket.com/albums/t458...ck9kiw.jpg]
Crist
Very nice restore on that Philco console Mr. Rottie . You have made it to the big times now. The quality shows Icon_eek  Icon_eek Icon_eek Icon_eek Icon_eek Icon_eek I think now that it would be a good time to come up for some air. Icon_biggrin
There are currently 7914 online users. [Complete List]
» 1 Member(s) | 7913 Guest(s)
