1931 570 Grandfather Clock
A friend local to my area recently picked up a 1931 Model 570 Grandfather clock, missing the chassis, speaker, speaker mount and grill cloth. He has all but the grill cloth. Does anyone know what grill cloth would have been on this model, or a decent high-res picture showing an original cloth? Thanks for any help.
Regards,
Jeff W.
Fresno, CA.
The cloth is the same as the 70.
Pete AI2V
Thank you, I'll pass along the pic and the info.
Regards,
Jeff W.
There are currently 7791 online users. [Complete List]
» 1 Member(s) | 7790 Guest(s)
