Another radio needing ID'ing
Check out these schematics:
http://www.nostalgiaair.org/PagesByModel...006009.pdf
Carl
Northern Panhandle, WV
Another radio needing ID'ing - by phly guy - 03-30-2009, 08:59 PM
Re: Another radio needing ID'ing - by Carl Travis - 03-30-2009, 09:23 PM
Re: Another radio needing ID'ing - by phly guy - 03-31-2009, 05:38 PM
