116B LO issue
I would try to measure continuity of the osc coil from the grid circuit through the band switch at common wiper point. You should be able to switch the band switch and measure all the different coil sections. This should confirm if it's a coil or a cap that's bad.
116B LO issue - by BrendaAnnD - 11-23-2015, 02:15 AM
RE: 116B LO issue - by BrendaAnnD - 11-23-2015, 11:41 AM
RE: 116B LO issue - by Kenneth F. Besso Jr. - 11-23-2015, 12:01 PM
RE: 116B LO issue - by Ron Ramirez - 11-25-2015, 07:18 AM
RE: 116B LO issue - by OZ4 - 11-23-2015, 01:54 PM
RE: 116B LO issue - by OZ4 - 11-23-2015, 02:39 PM
RE: 116B LO issue - by BrendaAnnD - 11-24-2015, 01:16 PM
RE: 116B LO issue - by OZ4 - 11-24-2015, 04:02 PM
RE: 116B LO issue - by BrendaAnnD - 11-24-2015, 09:11 PM
RE: 116B LO issue - by BrendaAnnD - 11-25-2015, 09:35 AM
RE: 116B LO issue - by OZ4 - 11-25-2015, 12:10 PM
RE: 116B LO issue - by Ron Ramirez - 11-25-2015, 09:54 PM
RE: 116B LO issue - by BrendaAnnD - 11-26-2015, 10:40 AM
RE: 116B LO issue - by BrendaAnnD - 11-27-2015, 12:21 PM
RE: 116B LO issue - by klondike98 - 11-27-2015, 12:43 PM
RE: 116B LO issue - by TA Forbes - 11-27-2015, 10:21 PM
RE: 116B LO issue - by BrendaAnnD - 11-28-2015, 11:29 AM
RE: 116B LO issue - by OZ4 - 11-28-2015, 03:44 PM
RE: 116B LO issue - by BrendaAnnD - 11-28-2015, 11:41 PM
RE: 116B LO issue - by Chuck Schwark - 11-29-2015, 12:10 AM
RE: 116B LO issue - by BrendaAnnD - 11-29-2015, 01:07 AM
