Philco 14B
(11-25-2015, 12:43 AM)skyscraper Wrote:  Thanks all!
Chuck, thanks! Do you have good service literature on the 14? I think I'll be placing an order if you do.
Yep, got all the info you need.  Just order when ready to tackle the Beast.
Icon_biggrin
Chuck
Philco 14B - by skyscraper - 11-24-2015, 01:20 PM
RE: Philco 14B - by OldRestorer - 11-24-2015, 07:59 PM
RE: Philco 14B - by Steve Davis - 11-24-2015, 08:47 PM
RE: Philco 14B - by Paul Philco322 - 11-24-2015, 09:23 PM
RE: Philco 14B - by Ron Ramirez - 11-24-2015, 10:46 PM
RE: Philco 14B - by Chuck Schwark - 11-24-2015, 11:48 PM
RE: Philco 14B - by Radioroslyn - 11-25-2015, 12:25 AM
RE: Philco 14B - by Steve Davis - 11-25-2015, 12:32 AM
RE: Philco 14B - by skyscraper - 11-25-2015, 12:43 AM
RE: Philco 14B - by Chuck Schwark - 11-27-2015, 01:13 PM
RE: Philco 14B - by Arran - 11-27-2015, 02:00 AM
RE: Philco 14B - by George Kirk - 11-28-2015, 09:04 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
