how do i identify my record player?
Hi
On the first, if you know it is a 42-1009 then that is all you need. Icon_smile
You can get free schematics from Nostalgia Air, but for much better quality schematics with all pertinent change notes, etc., contact Chuck at the Philco Repair Bench. The fee is reasonable and you won't be disappointed.
Links:
http://www.nostalgiaair.org/
http://www.philcorepairbench.com/schematics.htm
On the Philco 60, have you changed all paper and electrolytic capacitors? Also, the antenna and RF coils are probably bad. You will either have to rewind the primaries yourself (see Chuck's site for details) or have someone such as yours truly rewind them for you.
Edit: Pertinent links for your Philco 60 coils.
http://www.philcorepairbench.com/tips/svctip36.htm
http://www.philcoradio.com/rre/
how do i identify my record player? - by Guest - 04-02-2009, 03:15 AM
Re: how do i identify my record player? - by Ron Ramirez - 04-02-2009, 06:46 AM
Re: how do i identify my record player? - by Guest - 04-07-2009, 02:13 AM
Re: how do i identify my record player? - by Guest - 04-07-2009, 02:22 AM
There are currently 8667 online users. [Complete List]
» 4 Member(s) | 8663 Guest(s)
AvatarAvatarAvatarAvatar
