53-960 help with dial string
If you post some good pics of the radio I might be able to make sense of the drawing. The tuner shaft area is the part of interest. From the drawings it looks like there are three different strings or are there two different styles? Just how many different pointers are there?
53-960 help with dial string - by BrendaAnnD - 11-05-2015, 11:18 AM
RE: 53-960 help with dial string - by OZ4 - 11-05-2015, 01:04 PM
RE: 53-960 help with dial string - by OZ4 - 11-05-2015, 09:40 PM
RE: 53-960 help with dial string - by OZ4 - 11-29-2015, 11:28 AM
RE: 53-960 help with dial string - by OZ4 - 11-29-2015, 11:49 AM
RE: 53-960 help with dial string - by OZ4 - 11-29-2015, 12:06 PM
RE: 53-960 help with dial string - by OZ4 - 11-29-2015, 12:25 PM
There are currently 6502 online users. [Complete List]
» 1 Member(s) | 6501 Guest(s)
