53-960 help with dial string
So the condenser drive cord (the one with the ten turns) starts and ends on the knob shaft.  And it just winds back and forth meanwhile wrapping around the tuner condenser shaft.
The pointer cord wraps the knob shaft the 1-1/2 turns shown but both ends are at the tension spring.
Icon_crazy Icon_crazy Icon_crazy
53-960 help with dial string - by BrendaAnnD - 11-05-2015, 11:18 AM
RE: 53-960 help with dial string - by OZ4 - 11-05-2015, 01:04 PM
RE: 53-960 help with dial string - by OZ4 - 11-05-2015, 09:40 PM
RE: 53-960 help with dial string - by OZ4 - 11-29-2015, 11:28 AM
RE: 53-960 help with dial string - by OZ4 - 11-29-2015, 11:49 AM
RE: 53-960 help with dial string - by OZ4 - 11-29-2015, 12:06 PM
RE: 53-960 help with dial string - by OZ4 - 11-29-2015, 12:25 PM
There are currently 6365 online users. [Complete List]
» 2 Member(s) | 6363 Guest(s)
