53-960 help with dial string
I still think that pointer drawing might be wrong. I think the cord comes from the upper right pulley and then comes down around the right side of the knob shaft then does a figure 8 around the condenser shaft.
Clearly some engineer majored in dial cord stringing.
53-960 help with dial string - by BrendaAnnD - 11-05-2015, 11:18 AM
RE: 53-960 help with dial string - by OZ4 - 11-05-2015, 01:04 PM
RE: 53-960 help with dial string - by OZ4 - 11-05-2015, 09:40 PM
RE: 53-960 help with dial string - by OZ4 - 11-29-2015, 11:28 AM
RE: 53-960 help with dial string - by OZ4 - 11-29-2015, 11:49 AM
RE: 53-960 help with dial string - by OZ4 - 11-29-2015, 12:06 PM
RE: 53-960 help with dial string - by OZ4 - 11-29-2015, 12:25 PM
There are currently 5878 online users. [Complete List]
» 1 Member(s) | 5877 Guest(s)
