38-116 broken wire in sub-chassis
Can't help much but did find a comment by Ron that indicates the code 125 sub assembly is different from the code 121 assembly....and he did use the word "complicated". Icon_smile
John k9uwa from John and Jean Antique Radio posted some pics and comments for a 37-116.
38-116 broken wire in sub-chassis - by murf - 11-29-2015, 12:50 PM
RE: 38-116 sub-chassis removal - by klondike98 - 11-29-2015, 01:47 PM
RE: 38-116 sub-chassis removal - by Ron Ramirez - 12-01-2015, 09:55 PM
RE: 38-116 broken wire in sub-chassis - by murf - 12-01-2015, 11:30 PM
RE: 38-116 broken wire in sub-chassis - by murf - 12-02-2015, 05:33 PM
RE: 38-116 broken wire in sub-chassis - by murf - 12-02-2015, 09:30 PM
RE: 38-116 broken wire in sub-chassis - by murf - 12-03-2015, 06:24 PM
RE: 38-116 broken wire in sub-chassis - by murf - 12-03-2015, 11:09 PM
RE: 38-116 broken wire in sub-chassis - by murf - 12-09-2015, 07:23 PM
RE: 38-116 broken wire in sub-chassis - by murf - 12-09-2015, 09:47 PM
38-116 question - by murf - 12-01-2015, 09:17 PM
Restoring Philco 96
There are currently 6448 online users. [Complete List]
» 5 Member(s) | 6443 Guest(s)
AvatarAvatarAvatarAvatar
