Philco 511 transformer smell
Well, let's assume the primary is 115 or so. Filament windings would probably be two, one for the 6.3 volt string, the other, more heavily insulated a 5.0 voltage for the rectifier. HV windings (sometimes red, red/yellow/red) should be very close when measured by a reasonably good meter out of circuit. These readings would be with the set operating normally under the designed load factors.
Philco 511 transformer smell - by mgandalf - 11-24-2015, 10:17 AM
RE: Philco 511 transformer smell - by klondike98 - 11-24-2015, 11:59 AM
RE: Philco 511 transformer smell - by Steve Davis - 11-24-2015, 12:43 PM
RE: Philco 511 transformer smell - by mgandalf - 11-24-2015, 05:01 PM
RE: Philco 511 transformer smell - by mgandalf - 11-24-2015, 05:15 PM
RE: Philco 511 transformer smell - by Arran - 11-25-2015, 12:08 AM
RE: Philco 511 transformer smell - by Steve Davis - 11-25-2015, 12:38 AM
RE: Philco 511 transformer smell - by Phlogiston - 11-25-2015, 12:26 PM
RE: Philco 511 transformer smell - by codefox1 - 11-26-2015, 01:40 PM
RE: Philco 511 transformer smell - by mgandalf - 11-30-2015, 02:14 PM
RE: Philco 511 transformer smell - by codefox1 - 12-01-2015, 05:22 PM
There are currently 5878 online users. [Complete List]
» 2 Member(s) | 5876 Guest(s)
