38-116 broken wire in sub-chassis
The 400 ohm resistor needs to go from pin8 of the 6L7 to chassis gnd. I would suspect the the rf transformer lug is grounded also.
38-116 broken wire in sub-chassis - by murf - 11-29-2015, 12:50 PM
RE: 38-116 sub-chassis removal - by klondike98 - 11-29-2015, 01:47 PM
RE: 38-116 sub-chassis removal - by Ron Ramirez - 12-01-2015, 09:55 PM
RE: 38-116 broken wire in sub-chassis - by murf - 12-01-2015, 11:30 PM
RE: 38-116 broken wire in sub-chassis - by Radioroslyn - 12-02-2015, 09:11 AM
RE: 38-116 broken wire in sub-chassis - by murf - 12-02-2015, 05:33 PM
RE: 38-116 broken wire in sub-chassis - by murf - 12-02-2015, 09:30 PM
RE: 38-116 broken wire in sub-chassis - by murf - 12-03-2015, 06:24 PM
RE: 38-116 broken wire in sub-chassis - by murf - 12-03-2015, 11:09 PM
RE: 38-116 broken wire in sub-chassis - by murf - 12-09-2015, 07:23 PM
RE: 38-116 broken wire in sub-chassis - by murf - 12-09-2015, 09:47 PM
38-116 question - by murf - 12-01-2015, 09:17 PM
46-1201 Trip Switch Spring
So, Q1. Does anyone know where to get the spider. Q2. If there is no such place, what material is best? I doubt tin is...morzh — 09:43 PM
Arran The oxidation seems to go deep, a few layers. The break starts right there, but then it will occur on every la...morzh — 07:35 PM
There are currently 8339 online users. [Complete List]
» 1 Member(s) | 8338 Guest(s)
