42-PT88 missing loop antenna
Well, upon closer examination it appears that the loop is built into the wood cabinet. It's not missing at all but simply hidden. Now I have to figure out how to get the chassis out for service and still have a connection to the antenna.
Steve Chambers
42-PT88 missing loop antenna - by Steve Chambers - 04-04-2009, 08:22 AM
Re: 42-PT88 missing loop antenna - by Steve Chambers - 04-05-2009, 03:28 PM
Re: 42-PT88 missing loop antenna - by codefox1 - 04-05-2009, 03:57 PM
There are currently 8151 online users. [Complete List]
» 1 Member(s) | 8150 Guest(s)
