37-690X (De Luxe??)
 I think that whoever wrote the ad copy of the first ad simply made a typo, the description of the sets mentions "37-690 DeLuxe but the caption under the photo does not. There was a standard version of both the 37-116 and 37-675 that came without the teledial, hence models of either set with the teledial were the so called "DeLuxe" models, but all 37-690s came with the teledial so calling one a "DeLuxe" would be redundant since there was no standard version.
37-690X (De Luxe??) - by PTurney - 12-02-2015, 12:18 PM
RE: 37-690X (De Luxe??) - by Arran - 12-03-2015, 01:47 AM
RE: 37-690X (De Luxe??) - by Ron Ramirez - 12-03-2015, 06:34 AM
RE: 37-690X (De Luxe??) - by PTurney - 12-03-2015, 03:34 PM
RE: 37-690X (De Luxe??) - by Arran - 12-04-2015, 12:47 AM
RE: 37-690X (De Luxe??) - by PTurney - 12-04-2015, 12:10 PM
RE: 37-690X (De Luxe??) - by PhilcoJohn - 12-05-2015, 07:16 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
